Perfect pass question
  • Dave210TE
    • Apr 2010
    • 45
    • 2006 super air 210 TE
    Hi. I have a 2006 SAN210 and the perfect pass has just started messing about. Ok here is what it is doing. When I set the speed and gun the boat fast out of the hole the perfect pass will lock in fine but I don't like to drive that way. When I start to excelerate smoothly with a smooth throttle up to the point the perfect pass locks on the speed it will be to say it has locked but then will slow down about 4 mph the exacerbate quickly back up to speed and it will keep doing this. Have any of you guys had this problem or know what may be the cause?
    Thanks
  • crobi2
    • Dec 2010
    • 337
    • Texas
    • 2000 Super Air Nautique
    Probably the computer box for the perfect pass. I have heard other people talk about this and some have sent their boxes in for repair/replacement. Mine does it too (I have the stargazer upgrade). On the first startup it won't lock in and will hunt up and down like you describe. If I turn the engine off and then restart, the problem goes away for the rest of the day.
    Interesting to hear that if you hammer it out of the hole it locks in fine. Does it keep working correctly after that?
    Rob
    • shonuff
      • Sep 2010
      • 157
      • Atlanta, GA
      • '05 SANTE
      Have you tried adjusting the pull setting values in the settings menu? For Stargazer you have to play with the KDW value if it surges like that.
      2005 SANTE
      • SBRS
        • Jul 2010
        • 63
        • Rancho Cordova, Ca.
        • 2012 Ski Nautique 200 CB (current boat) 2013 Ski N
        Make sure after you advance the throttle to the set speed that you move the throttle beyond this point. This gives PP the ability to increase RPM's when needed.
        • Dave210TE
          • Apr 2010
          • 45
          Corbi2 no the problem will be there nearly every time I build the speed up smoothly. I always take the throttle past the set point SBRS
          • AirTool
            • Sep 2007
            • 4049
            • Katy, Texas
            There is a setting that allows throttling past the setpoint. You might want to be sure that is not ON.
            • vanislwake
              • Apr 2010
              • 113
              • 2001 Air Nautique 2000 Air Nautique 2003 Super Air Nautique
              Just call perfect pass they know everything I had a similar issue with my 07 210 with throttle by wire , is the 06 210 tbw? Anyways I had to adjust some settings as directed by a perfect pass rep over the phone and after that it was all good.
              Current '02 sante full '06 updated
              Previously owned:
              07 San 210
              05 Sante
              03 Sante
              01 San 210
              02 Air nautique
              00 Air nautique
              + another 15 non nautiques
              • scottb7
                • Aug 2011
                • 2198
                • Carson City, Nevada
                I had similar problem, twice. First time it was short in one of the connectors by the stepper motor. (not by the master module). one of the wires was not properly crimped in one of the plastic connectors. Fixed this myself, kind of a pita.
                2nd time i had a problem the gps puck went bad. had to buy new puck. like a hundred bucks if i remember right.
                call them .... you will usually get aaron adams.
                • hyparks
                  • Feb 2011
                  • 302
                  • Brownhills, United Kingdom
                  • 2001 Super Air 210
                  Yeah speak to Aaron Adams. Great guy, really helpful
                  Current
                  2001 SAN 210, GT40
                  Previous
                  1994 Mastercraft Pro Star 190
