Ballast tank sending units
  • core-rider
    • 1350
    • Huntsville, AL
    • 2003 Black SANTE
    My port side tank sending unit is reading the tank is always full, even when empty. I removed the sensor expecting to find it hung at the top, but it wasn't. When unplugged the gauge reads empty, but soon as the sender is plugged back in it is back to full. I'm going to swap sides tonight and see if the problem follows the port sensor to determine if the sensor is bad or something else. Does anyone know if a test procedure for these? I would assume it is similar to a fuel tank sending unit, but different manufactures use different methods of sensing. (volts-ohms-etc)
    Jason
    All black 2003 SANTE
    -- Southern Fried --
  • hyparks
    • Feb 2011
    • 302
    • Brownhills, United Kingdom
    • 2001 Super Air 210
    I believe its ground resistance. Don't quote me but think they are 30 to 140 ohms.
    Put test meter accross plug connections and I think if you move float to top of sender it should read 30 ohm and 140 at bottom.
    I had a faulty one last year and in sure that's what mine were.
    Hope this helps
    Current
    2001 SAN 210, GT40
    Previous
    1994 Mastercraft Pro Star 190
    • core-rider
      • 1350
      • Huntsville, AL
      • 2003 Black SANTE
      Okay, I swapped the sensors and the problem followed the sensor so I know the sensor is bad. I read it and the good one with a multimeter and the good sensor reads 245 ohm empty and 30 ohm full. The bad sensor reads 45 ohm empty and 30 ohm full. I know someone on here was trying to sell tanks awhile ago. If you are reading this and want to sell a sensor I'm interested!
      Jason
      • vanislwake
        • Apr 2010
        • 113
        • 2001 Air Nautique 2000 Air Nautique 2003 Super Air Nautique
        I have a sender for the real wedge tanks I can sell ya, I can measure it to be certain if you like
        Current '02 sante full '06 updated
        Previously owned:
        07 San 210
        05 Sante
        03 Sante
        01 San 210
        02 Air nautique
        00 Air nautique
        + another 15 non nautiques
        • hyparks
          • Feb 2011
          • 302
          Yeah knew it was 30 to something40 not far out by 100 lol.
          Venislwake do you have two? If so I still need a sender for one of my tanks. Can you measure the resistance to see if it is also 30 to 240. Also can you measure the length of the sender from the bottom to the underside of the mounting plate please. Pm me a price and shipping to the UK please.
          Current
          2001 SAN 210, GT40
          Previous
          • core-rider
            • 1350
            • Huntsville, AL
            • 2003 Black SANTE
            Sent you a PM...
            Jason
            • vanislwake
              • Apr 2010
              • 113
              Sorry hyparks I only have one as the other wasn't working when I pulled my tanks do I threw it out.
              Previously owned:
              07 San 210
              05 Sante
              03 Sante
              01 San 210
              02 Air nautique
              00 Air nautique
              • hyparks
                • Feb 2011
                • 302
                Ok no worries
                Current
                2001 SAN 210, GT40
                Previous
                • youngunz
                  • Mar 2011
                  • 150
                  • Barrie, ON
                  • 2002 SAN
                  I have two spare sender units from my 02 SAN sitting around if you are still looking for replacements
                  Now
                  2002 SANTE
                  • core-rider
                    • 1350
                    • Huntsville, AL
                    • 2003 Black SANTE
                    Vanis is already checking on one for me but if it doesn't work out will give you a shout.
                    Jason
                    • hyparks
                      • Feb 2011
                      • 302
                      I need one unit. Can you pm me details like I asked venislwake earlier in thread please.
                      Current
                      2001 SAN 210, GT40
                      Previous
