Guys,
I just put my boat in the water for the first time this year. Last week, I just had the boat serviced and he changed the impeller, engine oil, tranny oil. It idles great and starts with no problem. I used the blue stabil(ethanol) in the fall and stored it with a full tank.
I noticed while under power the motor is surging a little. It is almost as if someone is moving the throttle back and forth. It seems to accelerate just fine as well. It is only happening intermittentantly. We blew through a half tank or so yesterday. I topped it back off and it is still doing it. I also am noticing exhaust fumes a little more than I used to. It is not smoking at all. It just has a rich smell to the exhaust.
I was thinking two issues:
1. Bad fuel
2. Fouled Plugs- never been replaced the boat has 315 hours.
I am thinking that we should burn through the entire tank and then replace the plugs and put fresh fuel in.
Any other ideas I should look for?
Thanks,
sstexan
1. Bad fuel
Thanks,
sstexan
