RPM, Oil Pressure, Temp guages all not working
  • porkchop
    • May 2006
    • 10
    • Ohio
    What am I missing? I have a 2007 SANTE and only these 3 guages are out (RPM, Oil Pressure, Temp ). Is there a fuse or a breaker that controls these 3? Everything else is fine, and it runs fine. No check engine light and it does not go into limp mode.
    Thoughts?
    Thanks!
  • TRDon
    • Oct 2007
    • 722
    • MN
    I had 2 gauges working and figured out it was the gateway computer that went bad. I would check the connections in the back of the gauges and make sure the sensors are snug on the engine connection wise I mean. Did this just happen or what lead up to this problem?
    • porkchop
      • May 2006
      • 10
      • Ohio
      Thanks for the ideas. It was fine when I put it away for the winter. Seems to be something that went bad or got loose over the winter.
      • porkchop
        • May 2006
        • 10
        • Ohio
        Looks like it is my gateway box. Where did you order the new one. They are frick'n expensive!
        • RideButter
          • Feb 2011
          • 189
          • Fuquay-Varina, North Carolina, United States
          • 2015 A22 2014 A22 SOLD 2009 210 SOLD 2007 210 SOLD
          I had the same issue on my 07 210 turned out to be the engine ECM.
          Check the connector at the end of the engine towards the bow, pretty easy to disconnect when doing an oil change or winterizing.
          Edit: I had no engine information....no hours, no tach, no nothing, plus the pp wouldn't work because it was not receiving data as well.
          Check your connections before buying a gateway.
          [URL="http://www.ridebutter.com"]http://www.ridebutter.com[/URL]
