Fuse blowing on 2005 211 Perfect Pass
  • Justin1933
    • Feb 2005
    • 240
    • Orange County, CA
    • 2005 SV-211
    The Perfect Pass Fuse (behind the dash) on my 05 211 keeps blowing, and I don't know why. It seems to blow as I turn the boat off and then back on. Just curious to see if anyone has had this happen and what they did to fix this.
    Thanks.
  • Justin1933
    • Feb 2005
    • 240
    • Orange County, CA
    • 2005 SV-211
    Nobody?
    • nms1991
      • 477
      Check your wiring harness from the perfect pass to the servo motor on the engine. possibly a shorted or rubbed thru wire. check the harness to see if routed near the pulleys or the exhaust manifold.
      • TX-Foilhead
        • Mar 2009
        • 351
        • Kingsland TX
        I had a similar problem on my Centurion a few years ago. It was in the wiring with the big piece of shrink wrap. I think that piece is common to boats that use the servo motor. Once I narrowed it down to that I called PP and they sent me a replacement and said what every is in there is not repairable. Mine would blow the fuse everytime I started the boat. I think something got broken while I was removing things to replace the floor and stingers.
        • Justin1933
          • Feb 2005
          • 240
          • Orange County, CA
          • 2005 SV-211
          Thanks very much. I will give them a call.
