I just replaced the plug and it lights up when I plug it on, but the pump doesn't try to power on. Is there an internal fuse? If so, how can I get to it?
From http://www.fatsac.com/Support.bifh
"The first thing you should check is the fuse. It's located inside the tip of the cigarette lighter adapter. To remove it, you will either have to unscrew the tip from the adapter, or push the tip in and turn it to align it with the slots. Once aligned, you can pull it out to gain access to the fuse."
Hope it works for you...I haven't ever had that problem. My old Tsunami is now in Phoenix.2010 Super Air Nautique 210 Team Edition
