I am a first time Nautique owner. I purchased a '91 Nautique Excel with 444 hours with a closed cooling system. Even though I test drove the boat before purchasing and the temp was fine, the first time I took the boat out after getting it home, the temp shot up over 220 so I limped it home and pulled out the RWP and could tell that it had not been serviced in probably 10 years. (I was a boat mechanic some 25 years ago) I replaced the impeller and cleaned up the pump and took the boat out again and running at 5mph it runs at 200 degrees and running at 24 - 36mph it runs at 185 - 190 degrees. I have searched and read several threads and it looks like everyone is shooting for temps closer to 160 even though the PCM manual says that the normal operating temp for a closed loop cooling system is 180 - 200 degrees. The question is, am I missing something? Should I be trying to get this thing to run cooler?
