Hi, I have a 2007 210 with the 330 excalibur,went out today and the engine was idleing a bit rough.Powered up with full ballast was a bit sluggish but no misses.Travelled for about 5 minutes and the red engine light came on. Did not go into limp mode. Throttled back light goes out.Temps and pressures seem fine.Light only comes on when doing 3000 to 4000 revs soon as you back of the plane light goes out. Only seems to not idle smoothly some times and lack a bit of holeshot. Any body have any ideas on what the problem might be. Thanks
You need to read the camshaft retard bulletin and see if you are in it.
You don't say how many hours you have....if more than 100, you should pull your distributor cap off and inspect. Vacuum off all the metal fuzzies and give it a try. If you have a cap and rotor, just replace the them while you are there. I'm at 325 and probably on borrowed time. I meant to do that as a winter job and, well, you know how that goes.
Be careful when you put the screws back in, the ears on the dist'r are plastic. I broke one off on the 5.7 (Excalibur - just kidding) in my Tahoe and I went back with a billet aluminum Accel to eliminate that problem.
Originally posted by nms1991 View PostCheck your knock sensor make sure it is hooked up and properly tightened.
pdnaut - did you read up on the camshaft retard recall? ....are you in it?
