Help Needed: 03 SAN upgrade to Ballast Pupies
  • mnwakerider
    • May 2011
    • 271
    • Minneapolis, MN
    Hey Guys hoping you can help me out as I am out of ideas/knowledge at this point.
    I am upgrading the aerator pumps to Jabsco ballast puppies. I have these schematics from Nautique on how to wire the system via relays. Here is my problem: on only the starboard fill when I hook up the leads from the PME box I always blows the 30 AMP inline fuse. It blows before I hit the switch on the keypad. It actually blows when I connect the battery. Trying to isolate the issue I added the power from the batter, the ground, the lead to the pump, positive from PME (white/yellow) and then when I added the negative lead from the PME and only then it blows the fuse. The oddest thing is it only happens with Starboard fill. Everything else works perfectly (port and belly fill and drain). I have tried everything I can logically think of, but I am not an electrician.
    Any help or ideas? I finally have the boat with easy access so I can get to it daily to try other things.
    Thanks!!
  • mnwakerider
    • May 2011
    • 271
    • Minneapolis, MN
    Anybody? It is killing me that only one of these doesnt work...
    • Chexi
      • Apr 2025
      • 2119
      • Austin
      • 2000 SAN
      Sounds like a bad ground to me... possibly in the pump itself? Have you tried switching the pumps to see if the problem is with the pump or the wiring?
      Now
      2000 SAN
      Previously
      1999 Air Nautique
      1996 Tige Pre-2000
      • ski4evr
        • May 2010
        • 613
        • Bowling Green, KY
        • 2005 SV 211
        I agree with Chexi, you should check the wiring and or the relay. You are creating a short to ground when you connect it up.
        2005 SV-211
        • mnwakerider
          • May 2011
          • 271
          • Minneapolis, MN
          So I bought a new relay and that didn't change a thing... Same with changing the pumps.
          I just picked up a multimeter. How can I check the quality of the ground with one? Or other ways of verifying the quality of the ground? It would be odd as I have all of the grounds going through a distro block but it has to be something!
          Thanks for the help!!
          • RideButter
            • Feb 2011
            • 189
            • Fuquay-Varina, North Carolina, United States
            • 2015 A22 2014 A22 SOLD 2009 210 SOLD 2007 210 SOLD
            You should be able to check for continuity between ground and power with the power disconnected, if you have continuity, i suspect a short over a bad ground. You are blowing the fuse on the pump side of the circuit before you press the button? I would also suspect the the possibility that the relay is closed as soon as you energize.
            [URL="http://www.ridebutter.com"]http://www.ridebutter.com[/URL]
            • mnwakerider
              • May 2011
              • 271
              • Minneapolis, MN
              You are correct. The fuse blows as soon as the ground is connected without any "communication" from the switch to engage the relay.
              I tested the ground from the block by going straight to the ground terminal on the battery with a test lead. The same thing happened. Does this help prove or disprove anything?
              • RideButter
                • Feb 2011
                • 189
                All you have done is added another ground lead from the battery to the engine block. I would look at your wiring from the pump to the relay. If that relay is closed, and the wires from the pump to the relay are shorted, that would cause that breaker to open.
                • thedude
                  • Apr 2007
                  • 451
                  • SW PA
                  MN, did you get this all figured out?
                  • mnwakerider
                    • May 2011
                    • 271
                    • Minneapolis, MN
                    Nope, taking it to the marine electronic tech my dad uses this week. I will post up what he says is the issue and how to get around it for future reference.
                    • mnwakerider
                      • May 2011
                      • 271
                      • Minneapolis, MN
                      The marine electronic tech was able to figure it out... NAPA gave me a bad relay. They gave me a single throw and not a double throw relay. Meaning no ground when the relay is open. Switched it out and everything works just fine! Knew it was something stupid I couldnt see... Just wish I would have know that was the issue.
                      Thanks for the help and thoughts guys! Now off to the lake to fill the extra ballast off my sweet key pad.
                      • thedude
                        • Apr 2007
                        • 451
                        • SW PA
                        Great news glad you got it figured out! Do your relays have an internal diode? When I did my install the original relays I used didn't, with the motor running if I went to turn off a pump it would cause a voltage spike and cut power to the dash and perfect pass for a split second (perfect pass would surge then regain speed control). It was kind of annoying, so changed all the relays to one with an internal diode. They were about $5 each.
                        • mnwakerider
                          • May 2011
                          • 271
                          • Minneapolis, MN
                          Not sure on the internal diodes. How would I check that?
                          • mnwakerider
                            • May 2011
                            • 271
                            • Minneapolis, MN
                            Mine does this now! Bummer... How did you find relays with the internal diode?
                            Got the boat out this weekend to play with the system. Couple of little tweaks left (seats getting pushed up, extra hose etc). But fill and drains all worked great.
