Impeller o-ring grease/lube
  • jmo
    • Mar 2006
    • 710
    • MA
    Hey Guys,
    So I noticed when pulling the impeller out last Fall to winterize that they used a light red grease on the o ring inside the RWP, anyone know what brand/type that is? Its on a 2006 Excal 330 196.
    Thanks,
    JMO
    2018 Ski Nautique 200 TE, H6
  • east tx skier
    • 1561
    • Tyler, TX
    I little water based personal lubricant works well on these sorts of things and will not degrade the rubber.
    • scott resick
      • Jan 2012
      • 532
      • Pittsburgh
      • 2006 196 Limited
      haha a litlle Astro Glide
      • jmo
        • Mar 2006
        • 710
        • MA
        So do you guys keep the personal lubricant next to the boot lube in the rear storage compartment??? You guys must subscribe to the "be prepared" motto...
        In all seriousness, I had heard that petroleum based grease is fine for o-rings and I would surmise its better than a water based since that will get dissolved through usage?
        • east tx skier
          • 1561
          • Tyler, TX
          In the past, when I ordered impellers from SkiDim, they would occasionally show up with a little plastic pouch of "water based lubricant." So, if that's what the manufacturer was suggesting (at one point) to help ease the impeller into the housing, it's good enough for me.
          And, no, I don't keep it in the boat. I keep it in the bed side table. If I have any trouble on the water, a little soapy water will suffice to keep things in place and help ease the impeller into the housing.
          • jmo
            • Mar 2006
            • 710
            • MA
            For reinstalling the impeller I use the same soapy water trick you do to get it in there and keep it lubricated until the RWP is fully primed when I dewinterize. I was only looking to continue using the same grease already in play for the o-ring as in that application I don't want it dissolving - maybe it doesn't matter though given it will stay wet.
            • surroundsound64
              • Jul 2005
              • 2147
              • Longview, TX
              • 2018 230 1981 Ski Nautique
              One CC dealer (can't remember who, it was so long ago) told me to use castor oil as it wouldn't degrade the rubber.
              2018 SAN 230
              1981 Ski Nautique
              Sold - 2011 Sport 200V
              Sold - 2000 SAN
              • scott resick
                • Jan 2012
                • 532
                • Pittsburgh
                • 2006 196 Limited
                I was told to use silicone spray. I changed an impellar once. And it worked.
