Steering Wheel Shake
  • ckdollar
    • Apr 2011
    • 52
    • Irving TX
    • 1999 Super Air Nautique
    I swear I have tightened everything I can find, but the steering wheel on my 99 SAN still shakes, and pretty bad while accelerating. Any ideas what I missed or need to tighten to get this back to normal?
  • swc5150
    • 2240
    • Eau Claire, WI
    • MasterCraft Prostar
    How's your prop looking? Check it for dings. It only takes a small prop ding to cause rattles and shakes.
    '08 196LE (previous)
    '07 196LE (previous)
    2 - '06 196SE's (previous)
    • ckdollar
      • Apr 2011
      • 52
      • Irving TX
      Yea, I had considered the prop as a culprit, but the wheel still shakes while not moving. Is it normal for the steering wheel to have a little give to it like that, and it is probably a prop issue?
      • hyparks
        • Feb 2011
        • 302
        • Brownhills, United Kingdom
        • 2001 Super Air 210
        My friend had this on his 04 san. There's a plastic type bush behind the steering wheel. My mates was worn causing it to shake. You could move the wheel side to side by just touching it.
        Current
        2001 SAN 210, GT40
        Previous
        1994 Mastercraft Pro Star 190
        • brianc
          • Dec 2004
          • 46
          • Europe
          • 1999 196 2005 196 team zr6 2005 226 team zr6 2007 211 team zr6 2006 196 excal 2008 196 limited z409 2010 200 team ob 343
          replacement bushing required
          • ckdollar
            • Apr 2011
            • 52
            • Irving TX
            Looking on nautiqueparts for a steering wheel bushing, but don't see anything. What part exactly are you referring to?
            • hyparks
              • Feb 2011
              • 302
              Not sure what its called. My friend removed his. Measured where it fits and made his own out of polypropelene. ( think that's how you spell it ) made it using a lathe
              Current
              2001 SAN 210, GT40
              Previous
              • nms1991
                • 477
                The bushings in the helm have worn, but teleflex does not offer replacement so if you want to replace the tilt helm replace it with the newer version which has bearings instead of bushings.
                • derekpfeiffer
                  • Apr 2012
                  • 35
                  • Nebraska
                  • 1993 Ski Nautique Openbow
                  If you had a pair of calipers to obtain the measurements required, I could make a new one for you and send it to you...or find a local machine shop if you don't want to spend the money on the newer style.
                  Doogie
                  2008 Larson 228 LXI 350 MAG Bravo 3
                  1993 Ski Nautique OB (tower ordered)
