Have a 94 Ski Nuatique with a PCM transmision. Getting it out of storage and noticed the transmision has fluid(red) in it. Have no clue what it is as I bought the boat last year. The manual indicates the PCM transmision needs 20W20 engine oil. What should I do here? Do I need to flush the transmision or is there fluid that's a suitable replacement for the 20W20 oil? Thanks for you help in advance.
Tags: None
My manual says to use dextron in mine.Doogie
2008 Larson 228 LXI 350 MAG Bravo 3
1993 Ski Nautique OB (tower ordered)
If it's red, my guess is that the previous owner already switched to Dexron/Mercon.1998 Ski Nautique (Red/Silver Cloud), GT-40, Perfect Pass Stargazer 8.0z (Zbox), Acme #422, Tunable Rudder.
Thanks for your help! I'm going to stick with the Dexron. Even though my transmission label reads "20W." I'm guessing at some point a dealer switched, the previous owners says all fluids were done by a dealer. The fluid in it looks great, but I'll replace this weekend anyway as the previous owner could not tell me how long it had been in the boat, couple of years, he guessed. The boat has only had 100 hrs put on it in the last four years........
