2004 Excalibur code
  • Bill
    • Mar 2004
    • 19
    • Snyder NE
    • 1969 Marauder19 2004 196 Ski LE
    2004 Excalibur code
    While working on the perfect pass bracket I Unhooked my throttle position sensor wire and started the engine. After seeing the error code pop up on dash and the boat running badly I realized I had not hooked up
    The wire. I have since hooked it back up and everything is running great but it still
    Throws the code on the dash. Anyone know how to reset it? Thanks Bill.
  • nms1991
    • 477
    Two different ways you can clear it with a scan tool or you can start and run the boat 80 times from cold to warm with out the code appearing again.
    • Bill
      • Mar 2004
      • 19
      • Snyder NE
      80 times? Any significance? Or is that their way of saying stop by a dealer and give them a $100 for a code clear?
      • TRDon
        • Oct 2007
        • 722
        • MN
        There is a device you can purchace that my dealer has let me borrow in the past (I have a very good relationship with my dealer) that is only about 40 dollars. I cant remember what it is or what it is caller but it is a device that plugs directly into the harness and will read you codes via blinking leds. It can also reset codes.
