GT 40 Exhaust Riser Gaskets
  • dan1166
    • 92
    Developed a leak at the exhaust riser gaskets, so I thought I would replace the gaskets. It turns out, that the new gaskets available are missing a hole. The original gaskets had a 6 hole water passage, but the replacement gaskets only have a 5 hole water passage.
    My question is has anyone used these new style 5 hole gaskets, without any problems? I would like so input before I reassemble the risers. Thanks again to all the members who have helped me in the past.
    Dan, the Skier Man
  • crobi2
    • Dec 2010
    • 337
    • Texas
    • 2000 Super Air Nautique
    The blocked passage should be toward the exhaust direction of the riser. It is like this to force water over the whole riser than be able to take a shortcut at the exhaust end of riser.
    If you got the gaskets at ski dim or White lake you can call them to confirm.
    Rob
    2000 SAN
