2002 super air ballast pumps
  • mike32
    • Apr 2012
    • 52
    • lancaster ohio
    • 92 ski 02 super air
    Are these factory pump rebuildable? Can you change the impeller? Also does anyone have a part number for the fresh water impeller? The ballast pumps run but dont pump very much. Does anyone separate the controls for front pump and rear pumps? Any ideas on how.
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    You do not have impellers in your ballast pumps. They are aerator pumps. You may have priming problems or your pumps aren't working and you are just getting filled by the scupper thru hull.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • mike32
      • Apr 2012
      • 52
      • lancaster ohio
      So as long as they run then they should pump? They have always worked before but this time they didn't.
