OK, I've swapped in the new gauges. My boat is a 2000 SAN, it does not have PP, but it does have "correct craft cruse by perfect pass"... this uses a jumper wire that attaches to the tach signal wire, and it just operates off of RPM, so there's no other connection with the gauges (except I was surprised to see that it grounds and gets power from the oil pressure gauge or some other random gauge... anyway, my question:
I don't want to drill a hole in the bottom of my boat and install the paddlewheel, because I'm scared. I know it's not a huge deal, but I'd like to avoid it. Not having PP, the boat does not have a paddlewheel. It has those 'pitot tube' pickups on the transom below the swim deck. There are two of them. I'm wondering if the signal wire (or wires?) from those will power the Faria MPH gauge. There are a few unused wires from the old harness going to the digital gauge, and I'm assuming one or two of them are the signal wires... does anyone know if I can hook those up to the new gague and avoid drilling? If so, which wires?
Also, the Faria instructions refer to the "IGN" terminal on the back of the gauges... there is no "IGN" terminal, but there is a "BAT" terminal. I'm assuming these are the same, but just for peace of mind... same thing?
