nautique 200 overheating
  • lilet
    • Apr 2011
    • 39
    • greece
    • Nautique 200 CB Nautique 196
    hello,
    I have a Nautique 200 2010 model PCM 5.7 with 1000 hours.
    will towing at about 2.500-3500 rpm the temperature gauge goes from 175 to 200 degrees
    and in about 20 seconds drops again to 175. engine check light flashing some times. It is not
    happening every time cause on the way to the port for example was cruising at 3000
    for 5 minutes and temperature was at 175 all the time.
    do you have any suggestions?
    I've changed the impeller, check tha sea strainer and water intake.
  • AirTool
    • 4049
    • Katy, Texas
    Your thermostat in the block is sticking and/or slow to open.
    By the way, you now have the record for hours per year on a 200.
    • migs
      • Aug 2008
      • 703
      • San Mateo, CA
      • SAN 210 TE
      1000 hours on a 2010!!! thats what im talking about
      Migs
      G21 - En route
      SAN 210 TE (Finally)
      06 Sky Supreme V220(previous)
      05 Sanger V210(previous)
      01 MC X1(previous)
      99 Air Warrior(previous)
      • lilet
        • Apr 2011
        • 39
        • greece
        yes I know but it's for professional use! 1040 hours today!
        by the way I haven't change thermostat and temperature haven't rise tha last 40 hours.
        engineer told me that might be broken circulation pumb.
        • AirTool
          • 4049
          • Katy, Texas
          As the weather gets hotter your stat is opening more to start...probably past its "sticking point".
          • lilet
            • Apr 2011
            • 39
            • greece
            that's sounds right. still no problem with temperature again.
            thank you
