Carpet Repair Advice Needed
  • sodbuster88
    • Nov 2008
    • 368
    • Clayton, NC
    I have some carpet coming loose. What should I use to re-attach / adhere? Where to buy and any tips I need to be aware of? Thx...
    Peace..
  • ^zero
    • Aug 2011
    • 5
    • anchorage alaska
    • 1998 Ski Nautique cb
    You need to use a solvent based outdoor carpet adhesive. The best place to buy it is a flooring store or if you must a box store. Make sure you don't get any adhesive on the surface fibers. Apply pressure with weight if you can until it dries.
    • Skack
      • May 2010
      • 25
      • 1993 Nautique Excel 1985 Ski Nautique
      You can get outdoor/marine carpet adhesive from the section of Home Depot were the outdoor carpet/astroturf is located. Technically you should use the appropriate trowel to apply it, but for a small section I'd slap it down without worrying too much about it.
