Impeller
  • HS
    • Oct 2007
    • 1333
    • Sammamish, WA
    • 2010 SANTE 210 (Sold)
    Impeller
    http://www.nautiqueparts.com/impellerballastpump.aspx
    Going to switch over to these.
    I could use some installation tips.
    Thanks!
  • TxJole
    • Jun 2009
    • 898
    • Cedar Creek Lake TEXAS
    You don't already have greens in your boat?
    • TxJole
      • Jun 2009
      • 898
      Easiest way to install any rubber impeller is to use a zip tie to get it to "lay down" the correct direction on a work bench. With the zip tie still on it start it in the housing then cut the zip tie.
      • HS
        • Oct 2007
        • 1333
        • Sammamish, WA
        haven't even looked -- the fills and empty cycles seem to be prolonged so I figured it was time for a swap. . .are they stock on the 210?
        • TxJole
          • Jun 2009
          • 898
          I think so but I could be wrong. I know of u have a warranty claim they will replace them with greens, or Buxton will.
          • Miljack
            • Dec 2004
            • 1616
            • Charlotte, NC
            • '08 230 TE ZR6
            Joe had a great tip, hadn't heard that one before. To remove them, get a couple of the paint can lid openers/church key, and use the small end (paint lid side) to work behind/under the impeller to be removed, should pull right out with the two tools.
            I think the '08's didn't come with the green impellers as standard.
            2008 230 TE-ZR6
            • HS
              • Oct 2007
              • 1333
              • Sammamish, WA
              They were green. One came out easy by hand. Going to see if there's an improvement before replacing more.
