getting too much gas in the carburetor.
  • rocco13
    • Jun 2011
    • 3
    • Mississippi
    • 1988 Ski Nautique 2001
    I have an 1988 2001 Ski Nautique and it is shooting to much gas in the carburetor. I switch the Holley out and put a Edelbrock 1409 in and it is still putting too much gas in carb. Any help one what else to do?
  • Nautiquehunter
    • Jun 2008
    • 2080
    What is it doing? How do you know its a fuel problem? Points or electronic ignition?
    • rocco13
      • Jun 2011
      • 3
      • Mississippi
      When turning over it shoots gas out the top and there is puddles of gas on the motor. It will fire once then just keep turning over each time I turn the key. It has points. I am not sure if a fuel problem.
      • rocco13
        • Jun 2011
        • 3
        • Mississippi
        It won't start at all. Instead, fluid is being spit out of the carb.
        Occasionally it tries to fire up, but just spits a lot of fluid (gas?)
        • Eric206
          • Jun 2010
          • 15
          • Pacific Northwest
          • 206 Ski Nautique ZR6
          Check to see if the float(s) is set correctly.
