I am usually the guy helping my friends work out the bugs with Perfect Pass but this one on my own boat has be stumped. The system works perfectly in RPM mode. The analog speedo running off the same paddle wheel as the PP works perfectly. When I run the PP in speed mode for wakeboarding or surfing it does not want to hold a speed. Also the digital speedo is displaying speeds 2-10mph over actual speed? Likely the system is getting the same input speed as the display but it still does not make sense. I adjusted the kdw and nn today but the system is continually.
Any ideas?
Next move will probably be a system reset.
Mike
Any ideas?
Mike
