I Noticed on our new boat that while surfing i could hear a slapping sound under platform. I called dealer and he says its called platform noise. The fix would be to remove it and put silicone down before installing it back. Its not loose at all and i did a quick test by slapping water under it while docked and it does in fact make a loud slapping noise. Anybody else experience this?
Slapping sound from platform
Correct Craft Boats Owned
[URL="http://www.planetnautique.com/vb3/attachment.php?attachmentid=14108&d=1313461675"]2007 SANTE 210 (Magnum Trailer)[/URL]Tags: None
Mine does. Nothing to worry about. They move a little on the brackets and as the wave comes under it.
Originally posted by lucky7t View PostI Noticed on our new boat that while surfing i could hear a slapping sound under platform. I called dealer and he says its called platform noise. The fix would be to remove it and put silicone down before installing it back. Its not loose at all and i did a quick test by slapping water under it while docked and it does in fact make a loud slapping noise. Anybody else experience this?2010 Super Air Nautique 210 Team Edition
Originally posted by HS View PostSilicone as in a cushion like you see under glass topped tables or door silencers? Does it get placed on the top of the bracket so it is sandwiched in place between the platform and the bracket?Current Correct Craft Boat
