Installing prop for the first time?
  • 555nova
    • Aug 2011
    • 12
    • Montana
    • 03 Air Nautique 216 LE
    So I sent my prop off to be repaired over the winter and I am trying to reinstall it. I was following the instructions from the owners manual but when I install the castle nut I can't get the cotter pin to line up unless I back the nut off about one face. Am I doing something wrong or does e castle nut not need to be tight? The owners manual says to tighten it with a wrench, but I can't keep the prop from spinning
    Thanks Jason
  • TxHr
    • May 2012
    • 100
    • San Antonio, TX
    • 2007 Nautique 226 TE
    You can insert a 2x4 or 4x4 between the prop and hull to hold the prop while you torque the nut. Make sure you first install the prop w/o the key and mark the shaft. You will need to reinsert the key and seat the prop to the same line. Once you have done this you can then install/torque the castle nut and install a fresh cotter pin.
    • TRBenj
      • 1682
      • NWCT
      It is permissible to back off on the castle nut after torquing it down, in order to get the cotter pin on. The taper is what holds the prop on- the castle nut and cotter pin are there as fail safes.
      I would recommend lapping the prop on to ensure you have a good fit between the prop and shaft.
      1990 Ski Nautique
      NWCT
      • AirTool
        • 4049
        • Katy, Texas
        Ditto on the lapping. Be sure to use FINE not the coarse compound.
        Also, I disagree on blocking with lumber. If you are not using a torque wrench, put leather gloves on and hold the prop with your hand. Using a wrench or ratchet that is about a foot long is all you need. I can't remember the torque spec but it is relatively low. If you blocked the prop and get on it with the prop wrench, the nut is too tight.
