Had some trouble today at the lake. We were riding in our new (to us) 2005 210 and several times the boat would just die. It was almost like a switch had been flipped. Going fine and then "poof"...nothing. Each time the engine restarted fine and we would be able to ride for another 30 minutes or so. A couple of times it would die after a double up, or hitting another boats wake, so I thought "Hey, let's check and make sure the battery cables haven't been vibrated loose". Sure enough, the terminals were loose, so I tightened them down. But still, a little later, we'd be going in smooth water and the boat would die.
Finally, we had been just floating around for a while, just chillin', and my friend straps on his board and gets ready to ride. I punch in the code, hit the start button and nothing. Dead in the water. I flipped the switch down to bilge only and the bilge pump starts working. OK, we have power. Flip it back up, try to start the boat, every light on the panel is lit (?) and it won't start. The horn won't even blow. Luckily we were close to the ramp so we loaded the boat up and called it a day. Before we left, I tried one more time. The darn thing starts.
Anyone have any idea where I should start troubleshooting? Loose connection? Bad keypad? I don't even know where to begin. :/
