2000 SAN GT-40 questions
  • dirtweed
    • Oct 2003
    • 19
    One on each side of the block, one in each manifold, one in the bottom of the elbow to the raw water pump, one in the trans cooler, two on the V-drive.
    That's about it. If you do the drain and then run to refill, the motor will sound A LOT different until it fills up again with antifreeze ( a lot louder)
    • holmes
      • Oct 2003
      • 18
      • Minnesota
      How many quarts of oil go into the GT 40?
      • M3Fan
        • 1034
        Should be 5 quarts- 4 for the engine, one for the oil filter. Also, my aluminum gas tank will also spill gas out the vent as it expands and contracts, big time. Very shocking the first time this happened.
        2000 Ski Nautique GT-40
        2016 SN 200 H5
        www.Fifteenoff.com
        • Pratt
          • 69
          What kind of pump do you use to drain the transmission and the V-Drive?
          2001 Super Air
