Oil Pressure Reading 2002 Sante
  • wakehead
    • Dec 2009
    • 240
    What should the oil pressure reading be at on my 2002 SANTE ?
    If its lower then the norm what would cause it to be low?
    210 SANTE
  • nms1991
    • 477
    How many hours are on your last oil change? What weight oil? You should change the oil every 50 hours and use either 15w40 or straight weight 30 or 40w depending on your weather conditions.
    • wakehead
      • Dec 2009
      • 240
      thanks for the reply.
      At what number is the oil pressure guage supposed to be at ?
      210 SANTE
      • HS
        • Oct 2007
        • 1333
        • Sammamish, WA
        • 2010 SANTE 210 (Sold)
        http://www.planetnautique.com/Correc...s%20Manual.pdf
        Should be in here
        • jbg
          • Feb 2012
          • 21
          • Tasmania
          Keen to find out as well, Once oil is at operating temp, oil pressure at idle is around 10psi, going up to 40psi around 3000rpm. its an 04 Naut 210 team 330hp.. is this fine. Other boats I have owned are aroun 40psi at idle and 60 psi under load.
