How many hours are on your last oil change? What weight oil? You should change the oil every 50 hours and use either 15w40 or straight weight 30 or 40w depending on your weather conditions.
Keen to find out as well, Once oil is at operating temp, oil pressure at idle is around 10psi, going up to 40psi around 3000rpm. its an 04 Naut 210 team 330hp.. is this fine. Other boats I have owned are aroun 40psi at idle and 60 psi under load.
