My lions are crossed, or something
  • pj
    • Oct 2003
    • 323
    • Rochester, MN
    • 1991 SN 1996 SN
    I've been having trouble with my volt meter being out of whack since Perfect Pass was installed on my boat. I have been told many times (and am convinced) that there is no longer a sufficient ground to my guages after adding the PP into the system. I'm sure I saw a post on here last fall that showed a wiring diagram and explained how to add an extra ground wire from the guages to the wiring block. Now I can't find it. If someone knows where that is, or could re-post that would be awesome. Thanks.
    Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
