2004 Team 226 Team RPM and Speedo stop working
  • steveTexas
    • Jun 2012
    • 1
    • Fort Worth Texas
    • 2004 Air Nautique 226
    Hello. Reaching out to see if anyone had this problem before. Both the Tachometer and Speedometer stop working at the same time while driving. Even lost the digital reading part of it. It's like they lost power. I'm not sure if those are fused or not, but every other gauges are working. I found out at the same time that the bilge pump in the back of the boat wasn't working and water was collecting pretty bad, so not sure if water has anything to do with that, but i know the pump has been out for a while since I have noticed that before and didnt even know there was a bilge pump back there, as the 226 gives no access to that side of the motor. Anyway, if someone can give me pointers, I would appreciate. I hope its not the FARIA control box, because I don't think those can be fix, and they are expensive. Thank you
    Steve
  • Quinner
    • 2246
    • Correct Crafts
    I would start with checking the Faria Gateway Box ("control box"), all connections should be on the underside, ensure everything is fully plugged in, clean and free of moisture.
