I just bought a 97 Sport Nautique with the GT 40 Pro Boss.
The boat will just randomly shut down on me. When it runs it runs great. The previous owner just replaced the FCC last year. I replaced the fuel filter just to eliminate that issue. We found that it seems like the power is intermittant to the low pressure fuel pump. Sometimes when you turn the key. The pumps dont come on. Sometimes they do. If they do the boat always starts. Seems to run fine until I idle down and then sometimes it dies and sometimes it doesnt. If it dies usually the pumps dont come back on if you turn the key. If you wait a while and turn the key the pumps will come back on and it will start. I took it to a marine mechanic and they said that the pressure on the fuel rails seemed to be running low but they had not put it under load. They think it might be the high pressure pump which was just replaced. I kind of doubt it. Of course when they checked the power to the fuel pump seemed to be there.....my question is....should there be power to the fuel pumps all the time? I replaced the wires all the way back to the relays and replaced the relays with no change. Summers are short up here in MT....hoping someone has some ideas. I dont know which wires I should check next.
