2009 super air throttle issues
  • henjj
    • Jun 2010
    • 5
    The transmission will engage in forward and reverse but it won't speed up. This problem is intermitent. The TPS seems too test out fine. I'm not sure what engine it has.
    Any suggestions?
  • henjj
    • Jun 2010
    • 5
    Correction, it's a 2006 Nautique SV211.
    • henjj
      • Jun 2010
      • 5
      It has the 330 excalibur.
      • nms1991
        • 477
        you need to check the computer for codes but more than likely you have a bad connection in the ignition feed circuit to the engine.
        • AirTool
          • 4049
          • Katy, Texas
          Push the rev only button in on the shifter to see if you can get the engine to rev.
