2007 to current 210 gauge replacement
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    when i got my boat it came with 2 new large gauges for tach and speed. i guess this is due to small cracks around the buttons.
    When i first got the boat I thought I wouldn't bother changing but they are a bit cloudy as well. what is point of saving gauges for next owner?
    does anyone know how you get to the gauges? do you just take off bottom cover/fuse panel thingy and reach thru? or do you have to take apart dash?
    also any reprogramming necessary afterwards or just plug and play?
  • H2O
    • Jul 2006
    • 247
    Need to remove the top of the dash. I believe the padded dash pieces are "glued" down. Team Edition gauges are simply daisy-chained together (unplug old and plug-in new).
    • scottb7
      • Aug 2011
      • 2198
      I got it down...pretty much a pain. you just take off bottom cover and carefully loosen 2 nuts for each gauge. bring them out from the front, disconnect connectors, and reverse with new ones.
      • Slick50
        • Jul 2024
        • 6
        • Lake Graham
        • Graham, TX
        • 2007 SAN 210 TE
        I just bought a 2007 team edition. The speedometer did not work but the boat came with a brand new set of gauges. So i decided to replace the RPM gauge and speedometer just for a new look. When i hook them both up, neither one works. When I unplug the new RPM gauge and plug the old one back in the old one still works, any ideas?
        • MN Ryan
          • Aug 2020
          • 1250
          • Maple Grove, MN
          • 2007 SV-211 TE
          Slick50 Are the new gauges the exact same as the old? This era of Nautique utilized a Faria Gateway, which means your typical analog gauge is not a direct replacement.
          • Slick50
            • Jul 2024
            • 6
            • Lake Graham
            • Graham, TX
            • 2007 SAN 210 TE
            Hey Ryan, yes they look actually the same. I just took the cables off the old gauges and plugged them into the new ones. They are brand new in bubble wrap, makes no sense. see attached.
