Randon Check Engine Light and Limp Mode Causes ???
  • 7nautiques
    • Jul 2010
    • 12
    • Cumming, GA
    • 1988 2001 SN, 1990 SN, 1993 SN, 1996Sn, 1997 SN,1998 AN, 2005 AN, 2012 SAN 230.
    Just spend a couple hours wakeboarding and surfing behind my '05 Air 216. All of a sudden I am getting the check engine light and engine goes into limp mode. Let it sit for 20 minutes and then it ran normal all the way home. This happened 3 times in 2 hours while riding. Anybody know what may be the cause??????????? Thanks for any ideas you may have. 7natutiques.
  • wetfoot
    • Jan 2004
    • 90
    • SoCal
    What is the engine temp doing when in limp mode?
    I wonder if your impeller might be the issue.
    • TRDon
      • Oct 2007
      • 722
      • MN
      I know the oil pressure switch is known to be bad on that year. It is pretty cheap to replace. If you are having the limp home problem, and know where the switch is, you can disconnect it and you will get the check oil pressure light but the gauge will still work, but it will not go into limp home mode so it will still be rideable. I took one for a test drive and the same thing happened.
      • nms1991
        • 477
        the switch does not effect the gauge, if you disconnect the sending unit then you loose the gauge, so disconnect the sensor with the green wire and re test the boat.
        • Norsten
          • Jan 2019
          • 1
          • candlewood lake CT
          • Formerly owned several MasterCrafts but Recently bought a 2005 226TE
          Awesome! I’m a new 2005 226 owner, I’ve been lurking but this is my first post to thank you guys for saving me today. Went into limp mode, I was stressed about getting the check engine codes read and while on the water found some information on my phone but this info from 2012 saved the day. Those of you who generously offer your expertise are greatly appreciated by guys like me.
