Hope you guys can help with a problem.
It seems as though my starter may have gone out this weekend in my 2003 SAN 210 with Excal 330. When hitting the ignition at the keypad I only get one 'hit' of the starter and no action or even recoil at the belts/crank case.
Here is what I have gone through for checking:
Does all of this sound like the starter or the lead from the keypad/ignition switch or something all together different? Any other suggestions? My check engine light is on, but the boat is not running so I am assuming this is always like it in this state.
Thanks for all suggestions I really hope to get this resolved by the 4th. For the lake boat parade.
- Each time I try to start the boat via keypad I get one 'hit' from the starter then the entire system (keypad, speedos, stereo etc) dies, like entering code and hitting stop.
- Multimeter reads 3.6V at lead from ignition/keypad. Is that normal? I xpected 12v.
- Got more movement with test lead going straight from battery to ignition lead. No turnover, but more crankcase actually moving
- manually got one revolution on the crank case via 5/8 wrench with to make sure it was not seized
