Did I install my prop correctly?
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    2005 boat. I haven't done it in a while and don't feel like having to change it around in 105 temps tomorrow.
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Is that a nylock nut? If not, you need a castle nut. As for direction, you would not have been able to get it on backwards. The taper wouldn't have allowed it.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • Chexi
      • Apr 2025
      • 2119
      • Austin
      • 2000 SAN
      The taper should not allow you to put it on backwards if that is what you mean. Is that a nylock nut? If not, you need one or a castle nut.
      Now
      2000 SAN
      Previously
      1999 Air Nautique
      1996 Tige Pre-2000
      • gride
        • Jun 2007
        • 1441
        • War Eagle
        • 05' 210 team
        Yes it's a fresh nylock nut. I do realize I shoul know this, but do I need to crank the nut down so it's seated against the prop? I'll be lapping it Thursday, but I just threw it on this afternoon so I wouldn't have to do it at 7am
        • ski4evr
          • May 2010
          • 613
          • Bowling Green, KY
          • 2005 SV 211
          OM says max of 30 ft lbs. Seems a little loose to me, but thats what it says.
          2005 SV-211
          • gride
            • Jun 2007
            • 1441
            • War Eagle
            • 05' 210 team
            I read the directions. The prop has to be seated. Then it will "tighten" as it's driven. It's been about 2 years since I've changed one ans I forgot.
            • gride
              • Jun 2007
              • 1441
              • War Eagle
              • 05' 210 team
              The 1464 performed beautifully today. We had a full tank, about 3600lbs of total weight and she got on plane like it was almost nothing. Then, it was close to effortless to keep proper speed on a windy(as in curvy) river with no perfect pass. I could actually feel how much less the boat was straining when I got up.
              • ski4evr
                • May 2010
                • 613
                • Bowling Green, KY
                • 2005 SV 211
                what rpm were you running at say 22mph, 30mph?
                2005 SV-211
                • gride
                  • Jun 2007
                  • 1441
                  • War Eagle
                  • 05' 210 team
                  I have no idea. I only use the rpm gauge. I always assume the mph don't work
                  • Chexi
                    • Apr 2025
                    • 2119
                    • Austin
                    • 2000 SAN
                    I have the 1464 too. Great prop.
                    Now
                    2000 SAN
                    Previously
                    1999 Air Nautique
                    1996 Tige Pre-2000
                    • s_kelley2000
                      • 1575
                      • Fort Meadow Recevoir
                      • Mass
                      Sorry for the hijack but is anybody using the 1464 on a Python powered 210? My buddy just upgraded to a 220 so he needs LH props now and is willing to sell me the 1464 he recently picked up. I'll be able to try before I buy but just curious if anybody is using this set up and how they like it. Would love to know what you are seeing for RPMs when loaded up around 23 MPH and again at 30ish when empty. Thanks!
                      Shawn
                      2012 Blue Metal Flake SAN 230
