transmission fluid
  • palmerlakenautique
    • Mar 2005
    • 3
    • michigan
    transmission fluid
    i was wondering what kind of transmission fluid i need in an '89 2001 the manual says type "A" trade name dexron. could you tell me what kind i should use. it has a 351 motor with warner trans. i just bought the boat last year and this is my first service. thanks
  • skinautique
    • 1749
    • Colorado
    RE: transmission fluid
    if it has atf in it right now, use dexron III. I always use the mobil brand atf dexron III
    • nms1991
      • 477
      An 89 with a warner trans? Don't you mean the PCM 1.23/1 trans and it also used dextron.
      • SkiNautique2001
        • 60
        • Upstate SC
        My 89 2001 had 20wt oil in the tranny the first time I changed it. My dealer recommened flushing the tranny and replacing it with Dexron III since 20wt is so hard to find now. By flushing, he said to just change it 3 times running it for 5 minutes between each change. The tranny will be slightly louder with the Dexron according to PCM, but so far I can't tell any difference.
