I am thinking about reinforcing myself. But I think why not just mount the alum channel to the divider to keep it from bowing? Then we can still pull out the divider and not have the alum channel in the way. It would just come out with the divider. I am unsure if I would mount on the engine side or the other side. I think it would have same effect.
I had to add divider support. Kind of bummed to have to...But knew it was coming. Filling 1100 full was too much...I hate to block access to motor...I re-used the hole already drilled at top. Had to drill one hole at bottom. 1 inch by 4 foot polished steel. Sucker ain't bending... Only did the port side as that is where we surf. Was like $15.
Originally posted by scottb7 View PostI am thinking about reinforcing myself. But I think why not just mount the alum channel to the divider to keep it from bowing? Then we can still pull out the divider and not have the alum channel in the way. It would just come out with the divider. I am unsure if I would mount on the engine side or the other side. I think it would have same effect.
Did you ever try this?
