Exhaust Port Transom Leak
  • Sac Surfer
    • Jun 2011
    • 282
    • Mayfied NY, Burlington VT
    • 2010 - 210 Team Edition
    Hey Gang,
    Noticed my bilge coming on more then 1-2 times when parked loaded with gear and people, not a ton of water, but noticeable.
    After some investigation around the rudder and shaft seal, I was able to see some water coming in from the Exhaust port on the transom of the hull in my 2010 210. It's way down back past the rudder and in a very difficult spot, still got some fiberglass in my arms, but I was able to see that I'm missing 2 of the 4 screws(hardware) that hold this on.
    http://www.nautiqueparts.com/exhaustporttransom.aspx This is the part I'm talking bout, however it doesn't appear to come with any hardware.
    My question is does anyone have any idea what type of hardware holds this to the inside of the transom? You would think I would be able to get a socket on there but there is more then an inch sticking out, so not sure how I will conquer this one.
    Any thoughts ideas?
    Thanks,
    Mike
