Replacing ballast valve in 05 SANTE
  • Tpmc
    • Jun 2012
    • 10
    • Birmingham,al
    • 2005 sante
    My starboard ballast valve in the engine bay doesn't seem to seal correctly. When I turn it to the closed position, it wedges open slightly allowing the ballast to fill while under way. I tried tying it to the off position, and even when it's in the closed position, the starboard ballast still fills up on it's own. Has anyone done this fix on their own? I've found a little bit of info using the search function, but I haven't found enough details to take this task on yet. Thanks in advance.
  • lucky7t
    • Mar 2011
    • 1306
    • Oklahoma
    • 2015 SANTE
    Changed all three of mine in my 03. If yours are the same I have an extra 2 valves I got from nautique I think.
    Current Correct Craft Boat
    Correct Craft Boats Owned
