1980 Barefoot bung location?
  • Brad_K
    • Feb 2005
    • 55
    • Essex/Nottingham England
    Does anyone know where the bung might be on a 1980 Barefoot Nautique? There is not one under the swim platform where I expected it to be and can’t find one anywhere, I assume it does have one.
    Any help much appreciated.
  • bkhallpass
    • 1407
    • Discovery Bay, CA
    Assuming by "bung" you mean the plug, it should be
    in the engine compartment.
    Open the engine compartment. It should be in the front
    of the hole, approximately under the water pump/belts.
    It should be a brass handle which sticks out of the floor
    3 or 4 inches. It screws in and out.
    I dont' believe that any of the direct drive nautiques
    have a "bung" or plug in the back of the boat under the
    swim platform (though the V drives do).
    Hope this helps.
    If not, please disregard.
    BKH
    2001 Super Air
    • Brad_K
      • Feb 2005
      • 55
      I did see something there and I gave it a tug but as this is my first boat I was unsure weather it screws in or just pushes in and didn’t want to force it and break it, also where does it drain out from? The prop shaft maybe?
      • bkhallpass
        • 1407
        • Discovery Bay, CA
        Most of the time, your bilge pump provides the "drainage" of any
        water that might get in the boat. So long as you
        have it switched to the on position, the bilge detects when there
        is water in the boat, and pumps it out through a tube in the
        side of the boat.
        When you have the boat in storage, want to prevent the rain
        from filling it, etc., then you can remove the plug. Agian,
        the plug screws out. There is a brass femail fitting molded
        into the bottom of your boat. The male brass plug screws
        into it. When removed, there is an approximately 3/4 inch
        hole in the bottom of your boat, which provides drainage.
        Incidentally, the plug hole is also usually used to drain the oil
        during an oil change. The oil drain hose is placed through the
        plug hole, and the oil can then easily be drained into a recycle
        container from underneath the boat.
        Regards,
        BKH
        2001 Super Air
        • Brad_K
          • Feb 2005
          • 55
          Thanks, i will have a look tonight and see if i can take it out.
          • Brad_K
            • Feb 2005
            • 55
            Thanks guys, i found it and twisted out no problem.
            • BigBald
              • Jan 2004
              • 529
              • Indianapolis (Carmel), IN
              tried to resist the urge....but can't
              The bung location is dependent upon how hard you fall....head or butt first....and of course how good of construction your barefoot shorts and suit are......
              sorry
              88 Ski Nautique
              99 Sport Nautique
