Over the past several years I have been struggling with batteries on the boat. I have had multiple setups; where you have a stereo battery and starter battery. This year I added a total of three amps and have been having the same issue so I thought to ask the pros. At one time I had the common from my perko switch going to the starter and to my positive dist. block and I had severe engine noise. So, I went back to running the amps directly off the stereo battery.
General question: Battery 2 has a negative wire connecting to one side of the engine, shouldn't all negatives ground at the same spot? So I have a ground to the frame around the engine (aluminum or steel) and I ground everything but battery 2 there.
Symptoms:
When perko switch is on battery 1, the alternator will not charge, it shows 8-9 volts via the digital readout - this is a new deep cell costco battery - the question is why doesn't it charge?
When perko switch is on battery 2, the alternator will charge at 14v, but after heavy music the stereo battery drops low and I have to then manually charge it at night.
When perko switch is on BOTH, the alternator drops its charge to 12v or below, but I think its masking the drop because its running both batteries.
Ideally I wanted to run the positive block off the same line as the starter but engine noise was an issue - especially when battery was low.
I still have issues, when the stereo battery gets low - engine noise is bad and just get general white/blank noise bleeding through.
i would appreciate any ideas or comments as this has bugged me for years.
I have attached a diagram demonstrating my design, please offer some insight.
Symptoms:
