Port side rear ballast not emptying 2002 SANTE
  • wakehead
    • Dec 2009
    • 240
    HI All,
    I am having ballast issues. Specifically emptying the rear port side. WHen i hit the empty switch i can hear the pump behind the starboard side running but not behind the port side. The issue is I cannot feel the pump at all, I cant even see it. Can someone tell me where the empty pumps are located? Is there a wire or an inline fuse I can check?
    Also I do not have the rear starboard pump hooked up right now as I am ordering a new one. I dont think this would cause the issue of the empty not working.
    Any help would be great.
    210 SANTE
  • brhanley
    • May 2011
    • 18
    • Truckee, CA
    • 2002 SAN
    Below the tank in the stern of boat...I think you have to pull the tank to get at the pump.
