Why do the newer boats go through spark plugs so often? 09' 230....
Response from PCM tech dept. in S.C. is that even on the new engines, plugs should not wear out/burn out that quick. They should get well over the number of hours on my boat. I have about 340 hrs and the electrodes are almost gone completely, with white to pinkish porcelain. I think mine somehow got the wrong plugs installed at the factory. White should indicate a lean mixture.
Nordicron, I have had occasional run-ability issues since new, but that were attributed to fuel pumps (replaced under warranty). Seeing these plugs and with the response from PCM makes me wonder..
PCM just says to inspect annually. In 25 years of owning PCM engines, I don't think I've ever replaced plugs. I always checked once or twice a year, gapped them, and never an issue.Last edited by shag; 09-05-2012, 02:44 PM.
Shag which engine in your boat? I haven't replaced the plugs in my ZR390 yet, but will inspect at the end of season/winterizing time. I replaced the plugs annually on my Python powered boat, it almost always needed them...2008 230 TE-ZR6
If teh electrodes are almost burnt then you were running lean, I suspect your plug problem is related to your fuel pump(low fuel pressure) issue and they were damaged a long time ago but never replaced.
http://www.nautiqueparts.com/sparkpl...-platinum.aspx use the planet nautique discount for better pricing.
or
http://www.skidim.com/prodinfo.asp?number=RP030010 same plug different source.
The iridium plugs are what is needed in your 343 exc. Mine are 7 years old and have 275 hours on them, 90 hours of that is from this year.2005 Ski Nautique 206 SE, Acme 422, PP SG 8.0, ND Tower
Prior Boats:
1999 Ski Nautique GT-40
www.skiersofknoxville.org
for my ex343 I replaced mine with autolite app605 $36 plus tax for all eight. if i have it right then stock plugs r030010 cross to ac41-932 to ac41-993 to the autolite app605 i picked.
