So I probably did not do my research well enough before I started this project. I have a 2007 236 Team. I removed the rear hard tanks and added bags. In the belly, I took the over fill line and connected to the triangle bag underneath the front. Then used the overfill line off the bag to the side of the boat. It has been working great for 2 years. I just noticed last week that the belly tank has a crack and is leaking? Any ideas on how to fix the crack? It looks to be on the edge on the bottom of the hard tank. Removing the tank looks to be impossible without dismantling the entire boat. I obviously should have taken this vacuum situation a little more serious. A little late now. I may just have to bypass the entire tank and use a bigger bag or cut up the belly tank and remove? Any ideas? Thanks,
ps I have 750's in the locker. I think I am going to go to the 1,100 ones. Do they fit in the compartment totally filled up?
sstexan
sstexan
