Somehow I overfilled the oil.
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    I changed the oil/filter and removed 3.5-3.75qts of oil including the filter. I added 3 qts including the filter and checked it the next day after running it on the hose for 10minutes. The oil level seemed below the "low line" on the dipstick. I checked it out on the water and it was still @ the low mark. I planned to add a little today, but when I checked the dipstick it was over the full line by about 2 inches give or take. I also noticed this today.
    Some oil trapped on top of the filter(overhead view)
  • crobi2
    • Dec 2010
    • 337
    • Texas
    • 2000 Super Air Nautique
    It looks like that crimp style connector is leaking a tiny bit. Just an annoyance.
    Unless it starts to gush (probably wont happen)
    Rob
    • j2nh
      • Dec 2003
      • 628
      • Spread Eagle Wisconsin
      Is this a 343?
      How do you know how much you took out?
      How did you drain the oil, extractor or with the quick drain hose?
      If it is the 343 I know that a little oil can show a dramatic effect on the stick but not two inches!
      If it was my boat I would drain the oil measure what came out and compare that to the 3 quarts you put in. Check the color and consistency on the oil as well, looking for water. Check the filter as well and make sure it is full.
      Weird problem, I thought things like this only happened to me.
      2018 200 Team H6
      2009 196 Team ZR 409
      2005 196 Limited ZR 375
      2003 196 Limited Excalibur
      1999 196 Masters Edition
      1987 ProStar 190
