Just brought a 2002 san with a 350 chevy motor. Now that its time to change fluids eng/trans/vdrive. What do I need? Synthetics?
Conventional oils.
15-40 for the engine, five quarts.
Motorcraft FL1-A oil filter. I know, Ford filter, GM engine. The remote mounts needs the Ford filter.
Dexron 4 or Dexron/Mercon for the transmission, two quarts. You actually need only a little ore than one quart, but you have to buy two. Sorry.
V-drive takes a straight 30 weight oil, I believe non detergent oil is OK.
I would also get a new raw water pump impeller, you probably do not know how long the old one has been in use.
