I would like to paint my rear vents on my SANTE220. They are currently Silver Cloud with what appears to be a few stress cracks in each. Is that normal? These would need to be repaired and then I would like them painted gloss black. I have read where others have done this using a PPG epoxy paint. Any recommendations on who to use in the Minneapolis area for this work? Thanks for your feedback.
Have you had any body shop/collision work done on your vehicles? If so, ask them. It should be no problem for a body shop to do what you ask. The only thing is getting them to do such a small job. That's where a established relationship goes a long way.
Any good bodyshop can paint the vents for you. Powdercoating those vents is a NO-NO! The vents are either fiberglass/gelcoat, or an acryllic or plastic compound in the later years.
With the new clear coat paints these days, the paint will last you a long time. I think sometime after 2008, CC changed the vent construction materials, so better check before the bodyshop starts.2008 230 TE-ZR6
