Perko flush pro
  • bobcrex
    • Jun 2011
    • 5
    • burlington ky
    • 2001 super sport correct craft nautique
    Perko flush pro
    Hey guys just wondering if anyone has used or heard of these. Was thinking about purchasing . Thanks
  • todda
    • Jan 2005
    • 281
    • Granite Falls, WA
    • 1999 SNOB
    I have installed one about 5 yrs ago, and have had success with it. No problems what-so-ever, and easy to install for what it is worth. I found it easier than climbing under the trailer to put up the kick-stand boot.
    Todd
    Todd Aalbu
    1999 SNOB
    66.5" HO S2
    • bobcrex
      • Jun 2011
      • 5
      • burlington ky
      Thanks Todd that's exactly what I wanted to hear.
      • CradGen2
        • Aug 2020
        • 1343
        • Horseheads NY
        I have a friend who has one on his 3 boats and loves them. I haven't gotten around to buying and installing.
        • Sac Surfer
          • Jun 2011
          • 282
          • Mayfied NY, Burlington VT
          • 2010 - 210 Team Edition
          I installed one in my 210 last year. Works great if you winterize, and suck antifreeze from a cooler. Just make sure you turn off the sea **** for the raw water intake.
          • countiemountie
            • Aug 2006
            • 63
            • Kalkaska and SE MI
            • 2024 GS22
            I was thinking about getting one of these for winterizing, but have read some negative reviews on west marine. I think a more durable option would be using the banjo couplings outlined in the "red neck" post on how to flush your engine.
            http://www.planetnautique.com/vb3/sh...on-Garden-hose
            Another option that I'm thinking of, banjo makes a 3 way valve. I think it should be a more durable option.
            http://productimages.grainger.com/is/image/Grainger/3DTG1_AS01?$productdetail$
            • AirTool
              • 4049
              • Katy, Texas
              Just be careful with valves that are designed to seal under pressure - we call that "self energizing"...I say that because in the area these devices are usually mounted, the water is under negative gauge pressure because it is being sucked by the pump.
              I've yet to install mine, but I think a tee with a hose cap/coupler would be better. I've got a bag of parts I bought the first winter and still haven't put it on.
                I would try to leave the cooling system as stock as possible.
                This is my solution to flushing an engine.
                http://www.planetnautique.com/vb3/sh...ushing+adapter
                The more places you add adapters and fittings to the cooling water intake of your boat, the more places you create for a failure. Parts left off cost nothing, and create no service problems.
                • TRBenj
                  • 1681
                  • NWCT
                  Im still at a loss as to why everyone likes to overcomplicate this.
                  To run on a hose, all you need is a simple in line tee in the waterline, to which you can connect a garden hose. About $15 in parts from Home Depot. Certain boats may require an extra shut off valve between the tee and the hull pickup if the hose routing prevents the RWP from priming. The only thing this set up does not do well is test the RWP... but that isnt exactly the norm for when you'd be using it.
                  Spending $50+ on a suspect plastic component with marginal reviews seems unwise.
                  1990 Ski Nautique
                  NWCT
                  • AirTool
                    • 4049
                    • Katy, Texas
                    Originally posted by TRBenj View Post
                    Im still at a loss as to why everyone likes to over complicate this.
                    I agree. I mentioned my plan was was a tee with hose cap/coupler. I've read of occasions where the flush pro adapter cracked at the threads. I've also read the spring/flapper thing can come apart and end up in your RWP. Sure, it is "cute" design but too many things to go wrong even if it were free. Even with a cute design, it still adds pressure drop which reduces water flow to the engine.
                    I'm with DC also, spend the money on some valves and fittings that make juggling the flow or suction of antifreeze easy and design it where all that comes OFF during normal operation.
                    • bobcrex
                      • Jun 2011
                      • 5
                      • burlington ky
                      Thanks for all the info guys. For the record wasn't trying to over complicate was just seeing if anyone had used the product. Thought it looked like it wouldn't last. Anyways thanks again for the info
                      • bobcrex
                        • Jun 2011
                        • 5
                        • burlington ky
                        Thanks for the link Daniel. I do like that setup.
