Transmission drain plug stripped/rounded off corners
  • Ryan_E
    • May 2004
    • 73
    • Texas
    I was winterizing my boat yesterday and the last plug I had to take off was the plug at the bottom of the transmission. When I attempting to loosen, the brass plug corners rounded where you put the ½ in socket extension into. Has this happened to anyone and if so what did you do to extract the plug?
  • Ryan_E
    • May 2004
    • 73
    • Texas
    BTW...This is a 2006 210.
    • GCSuper
      • Jan 2010
      • 292
      • North Texas
      • 2011 Super Air 210 2015 Super Air 210 on order
      There should be enough threads to be able to get large pliers or equal to get it to turn. That's a tight space for a large tool though. I changed mine out to a standard type plug. Much easier to see and deal with.
