Need Torque settings
  • jo-e90
    • Mar 2011
    • 72
    • us
    Replacing riser gaskets and need to know the torque ft lbs for the bolts going through the manifold.
    Also what is the torque for the thermostat housing hex bolts as well as the carb nuts.
  • ricofrancois
    • Jan 2011
    • 26
    • Santa Monica, CA
    • 1997 Nautique 196 Open Bow PCM GT40 EFI
    Hi did you ever find out the torque? What engine is it for?
    I am replacing gaskets on my 97 GT40 Manifolds and Risers.
    I found on the PCM Manual:
    Exhaust Manifold bolts: 18-24 FT/LBS
    should we assume it's te same for risers?
    1997 Nautique 196 Open Bow - StarGazer ZBox - 5.8 GT40 EFI
